Input Needed! [clutch problems]
    hey guys, i have a problem with the trans on my accord. first of all, it is an h22 if that means anything
    i just got a set of brakes put on today........they have to bleed lines in order to get the fluid back in correctly.......can that be a problem? maybe that bled the wrong line? after all, brake fluid does run through the slave cylinder which feeds the clutch
    also, when you put the clutch in, it stays in.......and doesnt pop back out when you take your foot off of it.....my guess is the throw out bearing. any of you got any ideas?
    and to top it off, the car wont even go into gear......sort of like when the car wont let you shift gears unless the clutch is in, or the car wont start unless the clutch is in
    so basically, i cant get it into gear, whick means i cant drive my car, and none of this happened until after i got the brakes installed
    please help.....all input is appreciated
    H22A Coupe For Sale!
    I think you need to bleed your clutch line. I don't understand what your breaks have to do with it. They are in completely different areas.
      the only reason i mentioned the brakes is because it happened after i got the brakes done.....they pulled out the lines and did ALOT of beating ang banging
      thanks for the input,,,I have NEVER had a problem with the car period until i got the brakes done
        Ok well, grease monkeys do some really fucked up things. In your case I am not sure where to start. But i can tell you one thing, whatever they did, it can't be good.
          thats for sure.....this ever happened to you
          my engine and trans was FLAWLESS until today
            The best thing i can say to u is to call the people that did ur brakes and tell them what happened. if they are real mechanics they should fix it for free since they did mess up.
            Originally posted by Dr.x
            You drive an almost 20 year old car, pretty much everyone can pay it off.. you dont need to be "ballin"
              Dude di you talk to those fuckers?Get them to fix your car ASAP tell them you want your money back!!!
              ILBB
              People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
              Mk3 Supra Member #2
              Originally posted by DarkShadow707
              The world needs to be reset.
                I used to go to my friend's shop. I left my car over there and they overheated the F22a as well as they borrowed parts from my car to fix someone elses. So then I said F that and I began what i call backyardin.
                Backyardin- Working on your Car your damnself because it makes no sense to pay idiots to break as much shit as you do.
                  EXACTLY
                  changed brakes and clutch myself...sheeit
                  I <3 G60.
                    fixed it myself.....started pumping the clutch hard....air moved out and fluid back in......works like a dream
                    thanks for the input guys
