I have a 1993 Honda Accord with F22az. I have an overheating problem but not like any others posted in the forums. My car leaks water out of a valve found on the cam cover side of the block. What is this little open valve? is it suppose to be blocked? How do I fix?????
Leaking water from behind block
* Not to whore*
But doing my balancing shaft belt I noticed a drip-drip-drip coming from a small hole slightly to the right of the timing belt on the back of the black (when looking at the block from the back ((fire wall) side) The hole is about 1/4" right ownerofheap? Water was slightly greenish tint?
- ZipcreatureLast edited by zipcreature; 09-01-2005, 11:27 PM.
Its called a bleeder valve I believe...someone correct me if i am wrong. The water pump in my dads van has one in there. We replaced it and it stopped dripping. I dont remember if our waterpumps have the same hole. If so waterpump needs replacing. Thanks zipcreature for that info. But I may be wrong at the same time cause i am thinking about a completely different vehicle.
Yep, thats probably the waterpump that is leaking. That little hole that ya'll are referring to is called a "weep hole". When the waterpump internal seal starts to leak, this passage diverts the coolant away from the waterpump bearing. If you start to see coolant seaping out of that hole...even just a little bit, it means that the waterpump is going bad and needs to be replaced.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Thanks Mr. Honda, thats what it was called. It was killing me when i posted it because I knew what it was.Originally posted by mrhondaYep, thats probably the waterpump that is leaking. That little hole that ya'll are referring to is called a "weep hole". When the waterpump internal seal starts to leak, this passage diverts the coolant away from the waterpump bearing. If you start to see coolant seaping out of that hole...even just a little bit, it means that the waterpump is going bad and needs to be replaced.
Even so, I still wouldn't want to take the chance....if its leaking, replace it.
