car wont start =p
    car wont start =p
    i get in my car to go buy some cigs, and it starts up fine, just like normal. i drive about 2 blocks away. go in the store come out, try to start my car and it wont start, the engine makes the sound like it's going to start when i'm turning the key, but it wont fire up. and it will keep trying to turn over as long as i'm holding the key, but wont fire up. almost like there is no gas, but i just put $10 in yesterday. should work...
    wtf..!
    ummm put more gas in and try to crank it
    then check for spark air and GAS
    Dynamic racing
    Look out for 4 point cb7 strut bars for dohc!!!
    bleh... i just put like 5 ounces of vodka in a 12 oz cup of mango iced tea...
      Same thing happened to me today, but I was on the highway doing 110, then once I hit 80 or so, the engine just turned off and hasn't started since...
      I called HondaFan81, and he suggested to check for the sound of the fuel pump engaging, if you hear it, it should be OK, then check your coil and ignition.
      I'll tell you what the problem was tomorrow once I get it fixed...
      My CB7
        check for spark air? how do i do that?
          aim me jboyce illhelp you
          Dynamic racing
            dont listen to micks....pull a plug wire off and hold it to something thats metal while a friend trys to start the car. if you have spark then you have a problem with fuel. report back to us asap. and stay away from micks. god. i cant stress that enough.
              umm dude thats what i told him
              well you cant talk i know lots of peeps mad at you
              Dynamic racing
                It Probably The Fuel Pump Relay My Car Does It Too It's Common
                You Just Have To Find It And Tap A Few Times It May Be Stuck
                It's On The Drvers Side Top Of The Dash It's A Gray Box This Could Be It If It Was Hot Out Today They All Do It
                  Mine did that once. It turned out to be a bad dizzy cap.
                  Originally posted by Junior Smurff
                  Nevermind guys, google search works wonders!
                  I don't have road rage, my car just goes faster than yours!
                  Accords are for winners. And Grandmothers. But mostly winners.
                  I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
                    ok i took out the spark plug wires and checked for a spark, there was nothing. i only checked 2 of them but neither gave me a spark on my knife.
                    so do i just need new spark plugs?
                    i put the knife on the end of the rubbery wire part, not the valve cover.
                      you touched the metal peice with your knife right? while someone turned over the car?
                      Dynamic racing
                        ok i change the plugs, .44 for the gap. and its still not doing anything. i dont see a spark from the wires, but i'm not touching it metal to metal. about half inch away.
                          is there anything else i can check before buying a new dist...i really don't have $180 to buy a USED one, i'm hoping there is a diff problem...the car started fine 5 minutes before it quit. i don't get it. i dont think i'm getting spark from the wires, but i didn't touch metal to metal, i put my knife about quarter inch into the end of the wire in that hole, and i didnt see anything.
                            Dude, don't replace the distributor. Try the ignitor (inside the distr..), if that doesn't work try the coil. At first I thought it was your main relay. But your car should have started in a few minutes.
                            But after you've replaced the ignitor and the coil, you've spent the same $180.
                            Better than all 3 though.
                            My swap thread
                            Main relay proplems?--DIY
                              well what if i just buy a new dist for $45, is that ok?
