just as the title states. i just got my motor swapped in (f22a1) with the a6 intake, header, and oil pan. whenever i accelerate i hear this ticking noise. normally ticking noises arent a good thing what could this be.
ticking sound when accelerating
My Members Ride Thread
You have to think outside the box to get IN the box!Tags: None
oils good, got a small leak but i make sure i have enough. how would i go about checking the valves. how do i adjust them?
check for an exhaust leak.Originally posted by mcdizzlejust as the title states. i just got my motor swapped in (f22a1) with the a6 intake, header, and oil pan. whenever i accelerate i hear this ticking noise. normally ticking noises arent a good thing what could this be.Can't complain, it was free!
Maybe you're hearing pinging. Hard to describe. Look it up. Heck, check your timing anyways if you just swapped your motor. Takes a few minutes.Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
http://www.honda.co.uk/owner/AccordManual/400/5-14.pdfOriginally posted by mcdizzleoils good, got a small leak but i make sure i have enough. how would i go about checking the valves. how do i adjust them?
yea the higher in rpms, the faster the ticking gets.
we did spill some power steering fluid on the alternator wen we removed t from the engine. could that have messed it up?Originally posted by TonKCheck the alternator for correct voltage...
Mine ticked on my truck, and it was pretty loud.
yea it makes the noise in neutral as well
yea my friend and i are gonna chang ethe oil, filter, put a the oil pan gasket on, the gasket for the plug, and are gonna adjust the valves tomorrow night. the damn pan leaks a quart of oil a day.
