"BRAKE LAMP" light ON?? the one that tells u something burnt out..
    i've cked all my rear end lights and they seem okay. I don't know why it is throwing it off. When I start the car it doesn't come on, but when I brake it comes on.
    I checked the back, the 2 on each side (blinkers + brake lamps) are fine. The ones on the TRUNK itself are okay too. I really dont know why it's throwing it off, or could it be that my bulbs just aren't correct??
    Any ideas?
    Thanks.
    hahahahah
    Any ideas?
    Thanks.
    so did u check the high mount brake light? thats probably blown.
      have someone step on the brake so you can check all of the brake lights properly and w/ and w/o the headlights on. LIke 91accord4door said, keep the 3rd brake light in mind.
      Honda-Tech Username: Lostcb7
      The cb7tuner.com OG.
        mayb one filament is blown but the bulb will still light up tho
        (129)Transactions and counting
          I have had the same problem for about a month now. I have no clue what is going on. I have checked every bulb and had someone press the break when i was watching and everything looks cool. Is it possible for the bulbs to still be bad even though everything looks okay?
          1991 Black Accord Coupe
          Sprint Lowering Springs
          Neuspeed/Koni Sport Shocks
          Suspension Techniques Front and Rear Sway Bar
          17" Motegi DP6 with Bridgestone Potenzas
          TSX HID Retrofit with 4300K Bulbs
          http://www.cardomain.com/id/sthrnba711
            i have the same problem for a while now 1yr or so its pain in the ass to see that light on but i dont care. i just want to know why its on . all the tails work and all the brake lights work. so what the fuck
              Same here. I mean it does get kinda annoying when someone rides in your car for the first time and says. "You got a break light out", even though i know i dont. Just wish i could find a solution or reason.
                bulbs are cheap enough replace everyone of them.
                  wow, i always thought i was alone. it's real annoying!
                    its just the sensor is really sensitive. A random idea is to get some bulb grease, and put i on all the bulbs, and put them back in(on the metal part). This way they make a good connection, and maybe wont falsely turn that warning light on.
                      i agree with aero, ive had this happen to mine, and i replaced all the bulbs and used a lil bulb grease on them, problem was fixed.
                      im finally back in a cb7 its like coming home.lol
                      93 ex accord coupe h22 SOLD
                      90 ex accord 4 door SOLD
                      91 se accord 4 door SOLD
                      92 lx accord coupe SOLD
                      93 ex accord 4 door SOLD
                      92 ex accord 4 door h22 SOLD
                      93 ex accord 4 door auto SOLD
                      92 ex accord coupe auto
                        darn ya. it looks good. all 4 brake bulbs are okay, even liscence plat light is on.. i was thinking perhaps the reverse lights blew out but no they are okay..
                        i replaced the signal lights already. i am curious if the brake lights are the only things that trigger the BRAKE LAMP or other lights in the electrical system?
                        anyhow thanks guys..
                        hahahahah
                          I had the same problem then I reset my ecu and it mysteriously dissapeard! Its still a mystery to me... btw all my bulbs were good too
                            haha maybe i'll reset ecu. thats just really odd. cuz it doesn't pop up but only comes up when i press brakes.. had it just came on by itself then that's proally a faulty wire/sensor or something.
                            hahahahah
                              thats happened to me a few times, i just unplugged and replugged the bulbs, it eventully stopped
                              www.maketradefair.com
