how hard and how do u replace a fuel filer
fuel-gas-petro-help-boom
Buy a new filter. Locate your old one (behind the intake closer to the passenger side). Undo the top side bolt first. Have a rag handy cause gas is gonna pour out. Then undo the side line. More gas should come out. Then, undo the holding clamp on one side of the filter (2 screws, only need to remove 1 to get it out). Bolt your new one in and use all the new washers it comes with. When it's done, turn the ignition to ON for a minute to let fuel pressure build up. Then turn the car on (might take a moment) and check for leaksOriginally posted by DoctorCipher...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
Just a quick, I'm an idiot, question... Why the hell does the gas tank hiss when you remove the cap?Originally posted by SteveB...and you'd be wrong. The fuel tank is NOT under system pressure.
You really think 60 litres of gas is kept at 40 lbs/inch?
You can start your car with the gas cap off, and it'll run just fine.
Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
that hissing you sound is air rushing into the gas tank...when you run your car down to very little fuel, it creates a vacuum effect in the gas tank, so when you pop it open, the air rushes into the tank to fill the void, hence the hissing sound...THANKS 6th grade physics teacher !!
list of my mods: suicide cup holder, arm rest stolen from fold down arm rest in the backseat switched to the front!: custom RUST and DENTS:: removed heat shield...lmao...I hate being a stock noob...don't worry, I'm learning FAST!!!!!
Yes the fuel tank is pressurized whoever said it wasn't, nonetheless I've been doing this all quarter and just did it to mine, pop off your fuel cap, pull the fuel injector fuse, and press in your schrader valve on the fuel rail to relieve the pressure, use a rag wrapped around it to catch the fuel, unbolt the old filter, bolt the new filter in, screw the cap back on put the fuse back in and start the car, congrats your done.
Because it doesn't approve of you?
Actually, seems to me that as the fuel level decreases, it creates a bit of a vacuum in the tank. Removing the gas cap with a full tank makes no hiss, but doing so with a nearly empty tank allows an inrush of air into the tank caused by a vacuum left by the lower fuel level.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Actually in new cars 96 and newer obd II to be exact alot of cars will run like shit with the gas cap off and you can throw a code, your gas tank isn't held at the typical 33-40 psi that your fuel rail is but it does hold pressure. Typical procedure to relieve pressure on all vehicles starts with removing the gas cap. It's for a reason, don't ignore that.Originally posted by SteveB...and you'd be wrong. The fuel tank is NOT under system pressure.
Yes, I know it'll throw a code for emissions, but it will still fun just fine.Originally posted by 91accordwagonActually in new cars 96 and newer obd II to be exact alot of cars will run like shit with the gas cap off and you can throw a code, your gas tank isn't held at the typical 33-40 psi that your fuel rail is but it does hold pressure. Typical procedure to relieve pressure on all vehicles starts with removing the gas cap. It's for a reason, don't ignore that.2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
when i removed the cap. i'm sure removing the cap and the method you posted work either way. thanx for the info.
