I got oil in my inktake tube and it's i think getting into my throttle. Iv been having idleing and hesitation problems and im thinkin this is it. Does any one else have this problem and know any thing about it?
Oil in throttle
now is it the whole intake tube down to the filter, or just up there where the breather goes to the pipe? sometimes with k & n drop in filters they leak and cause this.
your hesitation is mainly that oil most likley...clean out the throttle body and intake system and the pcv and then clean your IAC outWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Im pretty sure its from the head cuz i have a clear tube going to it and its all oil stained and wet. today i sprayd sum intake cleaner and got the oil out the intake and hopfull it work stop acting up. Last year i had a oil leak getting thru the seals gaskets to the spark plugs and those bastards sed they fixed it but theres still oil on my plugs, so im thinkin that could the main problem.thnx guys
Have you been dogging the ass out of your engine? Checked your oil level lately? You might just have so much blow by that the breather line is just pouring oil into the TB. How's the car run? does it feel weak?
The PCV valve is this little plastic thing in the valve cover that has a hose coming off it going to the intake plenum. If it where internally broken it would cause you to get oil into your intake plenum but it would be after your TB so you wouldn't see it.
It's always a good idea to replace that anyway.
Why didnt you just go to AutoZone and get a PCV Valve for about $3 and pick up some throttle body cleaner and do it yourself...Originally posted by 4thGen4dr
Well jus took my car to the shop and got the pcv wutever replaced and got the intake and throttle cleaned. Got it picked up same fukin problem but it seems not as bad. Neways i can hit 100 mphalot easier now with the throttle and intake cleaned out, Sweeeeeet!
but anyways, did the cleaning really help out that much, maybe I should clean mine.
JayHittin Switches - Draggin XhaustAlways Under Construction
gosh i had a DIY on cleaning the throttle body.
well glad things are well.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Wonder if it is piston ring oil blow-by...I think that's what Busted meant. I replaced my PCV not too long ago so I know that's in check. I sprayed that intake cleaner as well. I just received the seals/gaskets today for under the valve cover. I'm gonna replace the spark plug tube seals (have wet plugs) & valve cover gasket, install new plugs & change oil. I'm hoping it's just them stupid tube seals. Do a valve clearance check (cuz I haven't lately).I was also going to recheck the ignition timing because like Busted said....it seems it wasn't set properly. Lastly, reset ECU.
Right now, car burns one qt of oil in a week...man does it stink, gets inside sometimes when I run heat. So I hope this all stops (had camshaft & crankshaft seal replaced..so with all this I hope no oil leaks period!).
Now, if problem pursists I'd have to say it's most likely due to ring oil blow-by...in which I say f**k it & just wait to install my built engine.
