not starting problem - bad distributor
    hay guys having some trouble with my car maybe yall can help. the engine turns but it doesnt want to come start. i changed the fuel filter thinking that was it but nope i also changed the battery but nada. maybe its happened to someone but whoever has some info i would appreciate it
    did it just all of a sudden not want to start?? check the main relay, if you can locate it and tap on it, it should start, if that fixes it you should take it out and resolder the joints. there are instructions around here im sure.
      no i was driving and it just turned off on me.
        eek, I'm thinking something w/ the dizzy. Check for spark.
          You really gotta give more details...ok so you were driving and all of the sudden it quit on...Did it bog or just shut off?
          Did you check to see if you got any spark?Take one of the spark plugs out with the spark plug wire attached to it and have someone crank it.It has to be dark though and make sure that the threaded part of the spark plug is touching the valve cover or find a good ground so electricity can travle through.You migh get zapped so wear gloves.
          ILBB
          People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
          Mk3 Supra Member #2
          Originally posted by DarkShadow707
          The world needs to be reset.
            yep.. i second the check for fuel and spark...
              yea i was just driving and it turned off before it kinda of spudered and like the rpms went down and up real quick once
                Usually I would be an asshole and say soemthing like... "SEARCH!!" But I was having the same problems you are, so I'll help ya out. Read this:
                http://techauto.tripod.com/s.htm
                  check the dizzy
                  -1992 Accord EX H22 234whp 185wtq
                  -1993 Accord EX SOLD
                  -1995 Accord EX Wagon Daily Driver
                  -2012 GMC Canyon V8 4x4
                    yeah.. that def. kinda sounds like a dizzy problem... if your rpm signal was acting crazy.. like i said before.. do yourself a spark check and get back to us...
                      that happened to me too and it was the distributor
                        hey read my post!!
                        http://www.cb7tuner.com/vbb/showthread.php?t=35072
                        i had the same experience and it turned out to be the fuel pump!!
                        be careful with the connections cause i snapped 1 of the fuel lines and now im %#$@!!
                          it lives
                          sorry guys cant find my last post but i fixed my car and its running. turned out to be the entire distributor so i changed and now im happy. thanks to all who gave some info when i was freaking out. thanks
                            your welcome if you wanna find your post go to your profile and you can all the posts you made
