Relay maybe
    Relay maybe
    ok my car died at a light last night and had to be towed home and at first it sputtered a little and then all the gauges went blank and then popped back on... then at the light the car just dies and will not start back up sorry about not searching NO TIME... ok my car wont turn over... its cranks but no turn over and here is a list of what also does not work...
    wipers
    gauges
    clock
    windows
    a list of what. does work
    lights
    hazard lights
    sterio
    i assume its a realay of some kind... but please i need exact..
    from f22 to H22. still love the cb7.
    check some fuses?
      wipers
      gauges
      clock
      windows
      lights
      hazard lights
      sterio
      haha your car wont turn over because its hevy "'jk"but have you cheack to see if you have spark
        yes sir.... i had some kind of problem like that in my gs-r
        check your cap, rotor, spark plugs, check if you have spark(like person above said), spark plug wires... hope this helps
        JDMish R34-ed cb7 - SOLD!!
        Integra GS-R -
          oh i forgot... if you keep trying to start it you might flood the engine... start smelling to much gas... at least you'll know that the fuel pump works.. check that also... good luck
          Integra GS-R -
            alternator faulty maybe? i had that happen and the alternator was fuct. or check you connection to the battery.
            (129)Transactions and counting
              I would guess the main relay under the driver side dash. Buy when mine died a few weeks ago I could still use my headlights, at least. I did not have any reason to check the wipers. But the dash lights were on so...
              - Zipcreature
              Awesome!
              CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
                Could be the main relay (the one under the dash) my went out and the car just won't start, but he said that the car died at the light and if the relay is bad it wouldn't just die like that. once the car start it stays on, seems like an electrical problem of some kind. I could be wrong, but hey just my 2 cent.
                  maybe a ground went to shit? maybe...
                  dirty accord->
                  http://www.cb7tuner.com/vbb/showthre...threadid=13407
                  crappy website
