Hello Fellow Tunerz,
I'm Seeking Serious Help From Everyone, No Suggestion should be ignored.
I'll take any advice that is provide. Here's the Story.
I Bought 2 Honda Civic HB:
1st One is a CX AUTO Power Steering no AC
2nd One is a DX 5 speed No PS nor AC
CX had a Knock, Turns out to be shot bearings.
DX got hit hard, BUt Motor & Tranny are in good condition.
Both cars Started & Drove fine. no Overheating, Just the Knock in the CX motor.
I started the swap with the Motor/Tranny & Engine Harness from the DX All Peddles & Hydro Lines Filled & Bleed.
I thought i could get away with just using the AT ECU to start the motor...
OK I was Wrong...
then i swapped out the AT ECU & replaced it with the MT ECU..... There that should solve that problem.....
No......
Now I can;t get the Key out the Ignition.... AT Lockout.
OK....
Let's Pull the dash off & swap out the Harness Under the Dash!
There, That Should solve that problem
Here's the Problem....
I Already Swapped Over all the Proper Harnesses that belong to that Motor & the ECU... But No Start.
Here are the symptom: When turning the key to "Start" all im getting is The Radiator fan kicking on. that's it.
I Really need all your Professional Opinions....
Thx you all in Advance.
JB
OK I was Wrong...
No......
OK....
JB
