Hey I just got a CB7 yesterday for 300 dollars. Its a 93 LX. I just replaced the valve cover gasket, spark plugs, oil, oil filter, air filter and tranny fluid. It runs great!
My only problem is, when the car is moving(doesnt happen when the car is revving and stopped), there is a vibration/humming coming from the rear passenger side quarter panel. I thought it was the exhaust at first because it sounds like when you downshift to engine brake the car...I thought that the tranny was stuck in the same gear...so i changed the fluid...now the shifts are more smooth...but the noise is still there...I was thinking maybe it could be tire rub, or a worn bushing....or could it be because the tires are bald? please help. Thanks.
