Vibration/humming PLEASE HELP!
    Hey I just got a CB7 yesterday for 300 dollars. Its a 93 LX. I just replaced the valve cover gasket, spark plugs, oil, oil filter, air filter and tranny fluid. It runs great!
    My only problem is, when the car is moving(doesnt happen when the car is revving and stopped), there is a vibration/humming coming from the rear passenger side quarter panel. I thought it was the exhaust at first because it sounds like when you downshift to engine brake the car...I thought that the tranny was stuck in the same gear...so i changed the fluid...now the shifts are more smooth...but the noise is still there...I was thinking maybe it could be tire rub, or a worn bushing....or could it be because the tires are bald? please help. Thanks.
    My Ongoing CB7 Project
    IMO it could be the rear wheel bearing .. mine had that noise to when i bought mine, turned out to be the bearings at the rear.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      How much did it cost you to replace them?
        120 for the bearing... i didnt pay for labor coz my uncle did it for me.
          what if I just find a rear disc brake setup? and swap my drums out? what year(s) accord came with rear discs?
            you would still change the bearings if they keep making noise.. talk to a mechanic.. i cant help u much unless i can see it.
              is it only when u are moving, gets louder when u go faster? sounds like a rocket in a way?
              my guess is wheel bearing, lol thats the only thing back there that can cause it...
              good question....drums or discs....
              Retro!
              Hater
                4th gen USDM EX and SE came with rear disc brakes
                Members Ride Thread
                  I was thinking of swapping the whole rear suspension. Like timmyotool's rear disc DIY. here's some pics...
                  And that would eliminate my bearing problem...since a new bearing is like 120...and both the rear discs cost timmy 240 at the junkyard...what do you guys think?
                    that would work too.
