rpm problem.....
    rpm problem.....
    i know this thas been covered but on this case is different. everytime i turn my car on it has this bouncing rpm shooting up and down. also when i drive it is fine but as soon as i get to a stop light it does the same thing ( wont idle ).but the weird part is that im looking for the idle control valve and is not there. also the engine is a f22b dohc so the only search ive got was covered on the single cam. i checked sensors vaccum lines i even cheked my throttle cable to see if it was too tight. any ideas i would greatly appreciated. heres a pic of the engine, maybe it helps.
    SOLD-->10-09-06
    MY 2000 PROTEGE
    MY OLD CB7
    THE SWAP
    MY COROLLA TYPE-S
    dude, you have an IAC, it's the fast idle valve (FIV) that your missing.....
    correct me if I'm wrong?
      chich one is that?
      SOLD-->10-09-06
      MY 2000 PROTEGE
      MY OLD CB7
      THE SWAP
      MY COROLLA TYPE-S
        I know you have an F22B1 but this is my F22A1. It's just to give you an idea. Good luck.
          look underneath the throttle boddy on the backside. The plate should be facing the firewall. It's a pain to get to but it it do-able! I guess you researched and found how to adjust it so I won't go into that here. Good luck!
          My Accord History:
          91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
          -Patrick
            so you telling me the iac could be bad. most likely. how much$$$$ im looking at.
            SOLD-->10-09-06
            MY 2000 PROTEGE
            MY OLD CB7
            THE SWAP
            MY COROLLA TYPE-S
              dude...check your shit before spending any $
              My Accord History:
              -Patrick
                Try cleanin it....saves money.
                  Yeah. There's a thread in the DIY section of the site. Do a search for it and it'll tell you how to clean it out. And you may also want to tighten the FITV. Hopefully this will help. My car used to act like it was going to stall, then rev to about 2k RPMs, drop to nearly stall, revt o 2k, etc. That happened until I swapped the IACV, FITV, and air boost/starting valve off my old motor onto this motor. Now my motor only revs to 1k.
                    bad news from what i can see is bad. i cleaned and cleaned the piece of shit thing and still have a bouncing rpm. could it be anything else?
                    SOLD-->10-09-06
                    MY 2000 PROTEGE
                    MY OLD CB7
                    THE SWAP
                    MY COROLLA TYPE-S
                      call me..
                      ill help u fix it..
                      Praise The Lowered...
                        It is most likely your Fast Idle Valve.
                        The wax inside dries out, causing the bouncing RPM. It is common on older valves, and JDM engines that had the coolant drained for long periods of time.
                        You can try adjusting it, but that is a temporary solution only. It may last a long time, it may not.
                          Originally posted by WiKKeDV16
                          call me..
                          ill help u fix it..
                          the # you gave me doesnt work.
                          SOLD-->10-09-06
                          MY 2000 PROTEGE
                          MY OLD CB7
                          THE SWAP
                          MY COROLLA TYPE-S
                            rpm problem solved
                            thanks everybody for the help. i cleaned the (iacv) and adjust the (fitv) and worked great, it even has a smother idle. problem solved and no money spent.
                            SOLD-->10-09-06
                            MY 2000 PROTEGE
                            MY OLD CB7
                            THE SWAP
                            MY COROLLA TYPE-S
                              lol.. thanks for letting me know u werent coming...... que cojone....
