- Hello guys
- Good evening gentlemen, has anyone ever had a problem with the heat exchanger/cooler on the Honda Accord 1993 EX, this heat exchanger only came on the automatic Accord 1992/93 EX, and mine is showing small leaks of the pink fluid from the radiator
- If you notice, the one installed in the car is bigger than the one I bought. however, this exchanger that I bought, it also came from an f22a6 donor, which is the same engine as mine, but we see a small difference in the diameter. I don't know if the mechanic was lazy and wanted to leave, and said that the new one I bought didn't fit my car '-'
- If you have a rockauto link I would appreciate it, I looked there and haven't found it yet... maybe my English is terrible or you know it by another name hahaha
Help with heat exchanger/cooler
Tags: None
