Engine problem, smoke
    So, I was outside messing around today, and decided to rev the engine pretty high while in my driveway. I take it to about 6,000 rpm and I notice this light colored smoke coming out of the tailpipe (not sure if it is white or blue) and a lot of water too. What do you guys think it is? Note: I have only noticed this at very high RPMs, 5k+.
    I know someone is going to scream compression test. I guess I will bite the bullet and go ahead and get one of those guages. But I will not have time to do it until Sunday.
    Gary A.K.A. Carter
    [sig killed by photobucket]
    Well could very well be age.. I have 130k miles and mine will do that also.. Could be also that we tend to run a lil rich up high so might be some unburnt gas.
      If you have a cat. convertyer on the car that sounds about right. The water is from the cat actually working correctly, and most cars usually kick out a small amount of smoke at higher rev just because the amount of exhaust passing through the pipes in such a short period of time. A car could run like shit but not smoke at all, and at the same time, a car could be running excellent and still kick out some smoke at higher revv's.
      My Accord History:
      91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
      -Patrick
        Good, because this afternoon I was kinda freaking out because I was worried about where I was going to get the money for a swap. CB7Tuner saves the day! I might still do that compression test though.
        Gary A.K.A. Carter
          ok good then all my smoke q's are good. Damn this site kicks mucho ass!
            You wanna hear how obsessive/compulsive I can be with my car? I usually do a compression test after every hard driving session. I'll let the inside collect mud and dirt and I'll even kick the car for no reason...but I check to make sure things are mechanically straight ALL THE TIME!!!! My car smokes, but I do run slightly rich, I have straight pipe exhaust and no cat.....but it also runs with the H22 Accords so oh well, keep on smokin baby!
            My Accord History:
            -Patrick
              One more quick question Vacuum tester = compression tester?
              http://www.partsamerica.com/ProductD...artnumber=3620
              Edit: Nevermind, I am pretty sure they must be different now that I can actually find the tool on their website.
              http://www.partsamerica.com/ProductD...tnumber=CP7821
              Gary A.K.A. Carter
                different...comp tester tests pressure, not vacuum
                My Accord History:
                -Patrick
                  go to your nearest advanced or walmart to pickup a comp tester.
                  1)92 Accord lx - I/E w/ valves, springs and retainers. H22 bored to h23 not goin in this summer.--Totaled
                  2)92 Accord Ex - I/E and loving the sound.
                  3)89 Integra Lx - loving the new old-school.
                  ITS NOT HOW MUCH HORSEPOWER YOU HAVE, ITS HOW MUCH POWER YOUR HORSES CAN MAKE
                  Now serving the Red, White and Blue under the U.S.A.F
                  Now Working at.......Dyess AFB
                    dont buy the one in the pic, you need one with a hose extension on it. the one you showed wouldnt even reach to the spark plug holes.
