I was driving, and all of a sudden the engine started bogging really bad. I was just taking off with a bit of gusto, so I figured I must have put in 4th instead of 2nd (I didn't), and tried putting it back in. The tach moved, so it was still getting a bit of fuel at that point, but immediatly after that, nothing. I coasted into a parking lot, Tried to crank the engine... nothing. Turned it off, turned it back on, nothing, and I noticed the main relay wasn't clicking over. Swapped the ECU for my spare one... nothing, and main relay still not clicking over. Opened the service port on the fuel rail, turned the ignition to on, no fuel came out. Whatever the problem is, it has to do with the main relay, but this one is brand new, so I'm thinking it's indirect, something else not telling the main relay to click over. Where should I look for this something else? Also, I just went out to look for answers, I swapped out the main relay with a spare. As I thought, that didn't take care of it. Another thing I just noticed... the check engine light is on, even when I try to reset it, and won't flash when I put a jumper in the diagnosis spot to check the code (just stays solid).
fuel stopped mid-drive?
You wont here the main relay click well I usualyl dont listen for it. I listen for the fuel pump to prime. If its doesnt prime means no fuel to motor which means no crank. You sure its a fuel problem? Check your spark? Check the ECU swap it out and see what happens.
I have never not heard the main relay click over and had the car start. I swapped the ECUs immediatly and that didn't fix it. If it is a spark problem too, it would be a bit out of the blue. I'm worried about the fuel because when I opened the service port on the fuel rail it was dry, which means there was no fuel in the fuel rail. When I jumped terminals 5 and 7 on the main relay's harness last night I heard the fuel pump prime and could tell the whole system was empty back to somewhere in the middle of the car. Something's keeping the main relay from getting a signal. When I tested the wires, only terminal 5 (lead from the ignition) was getting power. There are something along the lines of 4 wires that are supposed to be getting power, and somehow the other 3 aren't.
Pull out the main relay and resolder it and see if that helps.
Originally posted by MealsyHe's already said he swapped out the main relay with a spare. Sorry no help, but would be interested as i'm having a similar problem.
i say replace the relay again..just because its new doesnt mean its perfect
Originally posted by jumpman83I was driving, and all of a sudden the engine started bogging really bad. I was just taking off with a bit of gusto, so I figured I must have put in 4th instead of 2nd (I didn't), and tried putting it back in. The tach moved, so it was still getting a bit of fuel at that point, but immediatly after that, nothing. I coasted into a parking lot, Tried to crank the engine... nothing. Turned it off, turned it back on, nothing, and I noticed the main relay wasn't clicking over. Swapped the ECU for my spare one... nothing, and main relay still not clicking over. Opened the service port on the fuel rail, turned the ignition to on, no fuel came out. Whatever the problem is, it has to do with the main relay, but this one is brand new, so I'm thinking it's indirect, something else not telling the main relay to click over. Where should I look for this something else? Also, I just went out to look for answers, I swapped out the main relay with a spare. As I thought, that didn't take care of it. Another thing I just noticed... the check engine light is on, even when I try to reset it, and won't flash when I put a jumper in the diagnosis spot to check the code (just stays solid).
yes he did nail ...i wanna kno how this pans out too..i havent had issues with it cutting off mid drive..but having issues at times starting it...going to the junkyard hopefully this weekend...gonna pick up a couple of these...and keep em in the car..and if i have issues again..just swap it out and see if it fixes the problem..
Originally posted by NAiL05He said he swapped out his ECU not his relay.
Originally posted by HF22Tid say trace things back from the main relay im betting on it being something stupid and little IM NOT SURE IF IM WRONG HERE BUT DONT WE HAVE A MAIN RELAY FUSE FOR SOME DUMB REASON damn caps lock
make sure you change that fuel filter aswell
