oil type
    oil type
    what oil type do you guys use?
    for me its the cheap stuff. autozone oil 20-50
    93 Accord LX Sedan (sold)
    Umm, the stuff Honda recommends.
    5w30, 3.7 qts off the top of my head.
    - Ghosty
    WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
    FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
      Ugh. Autozone oil is shit, that's like lubing your cock with sand.
        I know its shit but thats all I can affored at this time...
        btw is 20-50 hurting my engine?
          If you have to use dino oil, at least spend a few more bucks and go for Quaker State or something decent. 20w50 is fine as long as you're in a hot climate, and probably is your only saving grace keeping up those oil films on bearings with that shit-ass oil. Unless you're leaking like a motherfucker tho and need to use it to slow that down, you should be using 10W30 or 10W40 in the summertime depending on local climate and engine condition.
            Im in south-fl so 10-40 is what I should use?
              10W40 is what I would be using, but it wouldn't be that Autozone shit. Cheap oil evaporates and breaks down pretty easily so you might want to go on the safe side and use 20W50, seeing as you're in south florida and it's almost July.
              Anyway, stop using autozone oil ASAP, and go with at least Quaker State or some other good dino oil if you really are that fuckin' broke. Even if you use the best shit out there (RedLine) like I do, oil changes still only cost about $50 to do. Very cheap insurance for your engine.
                I say get some Royal Purpal Oil(Proven to give HP ) and a K&N Oil Filter.Be aware the oil is about $10 a quart at PepBoys.
                  yea i was using Honda motor oil that i got from the pops cuz he is a used mech at a dealership but he has been out of work which sucks because for me every 3000 miles was an easy oil change due to free cases of Honda oil and Honda filters but since he out of work i have been using...ummm...fuck i cant think of what its called..its a black bottle with a weird top....either way check out this hot pic i found of Motul models! Yay!
                    LOL. Usually in TX I use RP 10w30. As for royal purple I dont feel any gains....Too me oil is oil.
                      Castrol GTX High Milage 10w30 with Honda OEM filter, of course.
                      Gary A.K.A. Carter
                      [sig killed by photobucket]
                        I work for a bus company and they use 15w-40 high grade. you know the $$$ stuff and my boss uses it on his 84-86ish civic now since I have a decent amount of miles I'm gonna start using that stuff to see what will happend. I mean the honda 5w-30 is cool stuff. but I think its a little to thin for motor. just my .2
                        always out numbered never out gunned..
                          I use Catrol Syntec 5W-30, and after a while using it, the engine revs easier.
                          RICE COOKA!!
                            I used to use that
                              quaker state 10W30
