ok my dizzy cap screw, which allows you to adjust timing, keeps coming unloose. Which i just i the reason why my car isnt starting sometimes. What is this screw a grounding screw which is making my dizzy cap lose a ground. when i screw it in it gets tight then loose.
dizzy cap screw
I'm not sure exactly what screw you're talking about, but if it gets tight then loose it sounds like stripped threads. If it gets tight but loosens over time because of vibration, can you use blue threadlocker or something? I don't have a screw on my rotor, it's press fit, the distributor mounting bolts can be used to adjust timing (there are 3), and I don't know of a grounding screw??? Trying to help, maybe more info?
PM me and get it done right!
You talkin bout the cap itself or the complete distributor? If its the complete distributor did you use the correct bolt?
Should be a problem as unloose is the oposite of loose! LMAO I just couldn't resist that one. Sounds Like it's been cross threaded. Opps?Originally posted by pretty_ricky302keeps coming unloose.Momma told me not to look in the eyes of the sun,,,, but Momma that's were the fun is......
Steven Adler
1993 Accord EX JDM F22a6 4 door Sedan
all 3 keep going loose? ive installed only 1 and left 2 out and it held and ran perfectly fine.
Your ignition problem may not be directly related to the stripped bolt, even though it could still be some other part of the dizzy.
You could probably use a Helicoil. Get the kit that matches the threads of the bolt, drill out stripped hole and insert new threads. Sounds scary but actually works really well.
