HELP! Engine wont start!
    Hey...I just replaced my airbag...before I did it, I had to disconnect the battery...so I installed the airbag and SRS fuse...and it worked fine. SRS light turned off and everything. But now, the engine wont start. Everything(lights, inst panel, etc.) works. Brand new battery. I checked all the under hood and under dash fuses, and they are all good. But I did notice that the positive terminal is cracked...and I guess its not gripping the post tight enough. I just wanted to make sure that it wasn't a blown fuse or something I had to reset...any help would be appreciated. Thanks.
    My Ongoing CB7 Project
    Terminal cracked? Sounds like you just answered your own question. There is a lot of current draw when the starter is switched on.....
    1992 Accord LX - SOLD
      Tahnks man. Just wanted to make sure.
        Nope. Replaced terminal. Still no ignition. When I turn the car on, everything works. but when I turn the key, I just hear a click. and the engine wont even crank...any ideas? Help me out guys.
          Hey EJ,
          Did it start before you swapped the airbag?
          Omar | aww_shiet | Facebook | Instagram
            Originally posted by aww_shiet
            Hey EJ,
            Yeah. It started right up on the first turn. So I think I can eliminate the starter from the problem...any suggestions? anyone?
              Anyone? Please help! I want to get this thing running...
                damn it's hard to say... back track to before you swapped the airbag. (i know this is dumb, but) is everything as it should?
                  Yeah...I checked all the fuses and everything...
                    I'm an idiot! Turns out, my car alarm(which I can't use because I dont have the remote) has an automatic kill switch. When I disconnected he battery, It automatically engaged. All I had to do was hit the reset button(which was conveniently hidden under the carpet...). Anyways. Thanks guys for your help.
                      hahaha go fig..
