Stock flywheel timing marks... is there a mark for TDC?
    I don't have one to use as a reference at the moment, but I'm curious. Is there a mark for TDC?
    here are some pictures for reference. I too am wondering the same thing.
    this is 15degrees, where stock timing should be.
    and the next 2, i have no clue what they are.
    this is to the right of the 15degree mark.
    this is to the left of it.
      Not sure if its different for autos, but on mine its the red mark, where the white mark is 15 degrees...or is that opposite....?
        Yeah the white one is for TDC. Red for 15D.
        Metal Metal and more Metal!!!
        How much does your wheel/tire combo weigh? Post here!
        -=Suicide Crew Member #1 (only member so far)=-
        MY RIDE
        "I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
          Manual must be different. What Jose has in the pics up there is what I've seen...
          That other mark... the cross like thing... is that TDC?
            what i did...was take out the #1 spark plug and stuck something in there that wouldnt nick the piston but will rest on top.
            crank the pulley until i could find the highest point in where that object would sit.
            then looked thru the inpection timing hole to see what is TDC
              and what was it?lol. what marking did you see?
                well, i have an aftermarket flywheel and it turned up to be like a little hole.
                so im using thay right now.
                  If that marking there is what shows, then it'll be easy to line up a stock flywheel to the unmarked aftermarket one I have... then I can have my timing marks back!
                    well, after further inspection of my stock flywheel, there are like 4 white marks, and one red one. the red one is about 3 inches long, and the white ones are jsut dots. but the neither of the white ones line up with the 15D marking thats etched on the flywheel. so..wtf.
                      Yep, thats the one.
                      My swap thread
                      Main relay proplems?--DIY
