1 lil problem....
    1 lil problem....
    ok i got muh h22a in my car and i finally got around to wire it up.... =-) ok so now i tried to start it last night adn it cranked adn it started but then it was all like rough.......and it turned off couse this be my spark plugs.....? or cables or is it off time......? i would realy apreciate the help guys.......i miss driving muh car so please help with any information.....thanks the dizzle
    ・オレンジ(デミオのオレンジがなかなかいい味を…)
      ・ブルー(インプレッサみたいな感じのメタリック系が何
      ・その他随時考え中…
    ......今日までの道の愚かな米に屈辱を与えるためにHonda Accord は作られた。愚かな競争を従事させている間抹消されるところ倍数の敵ターゲット。CB7 Honda Accord 。道の王。自動車恐怖。........
    your going to need to provide more than that...by that description, it could be 143 different things
      could be the plugs, wires, distributer cap, etc. Might not hurt to narrow it down a little for us. What does that tach read when its running rough?
        this is gonna take awhile first off do you have any check engine lights on?
          yes i do have a check engie light on when i try to start it......ok to narrow it down i turn the key and it starts adn it runs for a bit and it but my car shakes like crazy.......and it turns off.......the distributer is new....its almost like if my car is runnin out of gas but there is fuel running thru
            ・その他随時考え中…
            uhhhhhh more info please............
              I have a feeling your plug wires aren't on in the right order
              Originally posted by DoctorCipher
              ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
                ok i start the car and it cranks and it turns on.....but only for like 3-5sec. and it back fires adn my car shakes like crazy.....i have all the wireing connected nothing is left unpluged except for the sensor that goes to my down pipe i beleive is the knock sensor......but it wants to start.......
                  ・その他随時考え中…
                  thats wht i tought too but im right here at work......so i wont be bale to try it till i get home around 12am.....lol
                    ・その他随時考え中…
                    try to find out what code it is and also please show us in pictures of how you have the sparkplug wires in which order its in on the engine and distributor cap.
                      Did the firing order re-wiring work?
                        ok guys ill post one up......thanks for the help and support to all muh cb7 nuikkas
                          ・その他随時考え中…
                          if it starts, shakes, then cuts out...could be fuel filter or something ive been experiencing lately--the fuel pump/relay...might also be plug/firing order.
                          Originally posted by Jarrett
                            probably firing order, when i did my plugs wrong the car started and ran but like shit, could it be that the H22 relies on such high compression that it didnt have enough momentum to stay running, so it stalled out? just be positive that your firing order is correct and go from there
                            -sean
                            Members ride 15.927 @ 86.76 (f22a1)
                            Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
                            Arcadia Green Crew #10
