Adjusting Idle help.
    what is a good idle setting 1,000? 800? 500? i noticed my dads 02 and 03 accord are about 900-1000.
    mine is about 750. when it gets to 600 i re-adjust it.
    Retro!
    Hater
      k, ima wait for some other peeps input, it seems like 900-100 isa a reasonable setting,
        u can put it that high if u want...in the engine there are lables that says what the idle should be...what i said is what it should but u can go higher...i just had a problem with shifting into reverse.
        Retro!
        Hater
          well, im going to message you on AIM now because i dont like using the forum for a conversation place... but say the idle gets fucked, if i reset the ECU will it go back to normal idle?
            if ur idle gets bad...or too high..just un-do what u did. turn that screw down...i would post the pic of the screw but my digicam sucks.
            Retro!
            Hater
              no need, i know wut the screw looks like, ima leave it alone its perfect as it is.
                how many turns to the left should it be if you close the screw all the way to the left?
                i noticed a high pitched sound with the intake and the radiator fan always turns on, is that normal? my idle bounces and i only did two things, 1 adjusted the idle screw 2 added coolant
                  That screw was never meant to be adjusted. If your idle gets low for a week or so, and then starts to bounce, it's a Honda thing.
                  http://www.hondapitstop.com/accord/t...le_adjust.html
                    so how do i put that screw back to factory settings? do you know the exact turn count?
                      Nope.
