what is a good idle setting 1,000? 800? 500? i noticed my dads 02 and 03 accord are about 900-1000.
Adjusting Idle help.
mine is about 750. when it gets to 600 i re-adjust it.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
u can put it that high if u want...in the engine there are lables that says what the idle should be...what i said is what it should but u can go higher...i just had a problem with shifting into reverse.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
if ur idle gets bad...or too high..just un-do what u did. turn that screw down...i would post the pic of the screw but my digicam sucks.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
That screw was never meant to be adjusted. If your idle gets low for a week or so, and then starts to bounce, it's a Honda thing.
http://www.hondapitstop.com/accord/t...le_adjust.htmlLast edited by Slateboy; 08-09-2004, 04:53 AM.
