What are some signs that your fuel pump is going bad?
Please help..
Please help..
That is what is *ucking me over that my mechanic cant just run a test and fix it.
often. And to answer about the fuel injector cleaner, no that wasn't used prior to it doing this. Even tho they are newer could I have a bad spark plug? It is either a spark or fuel issue. It does give me a hell of a time starting from time to time. I was doing alot of reading here and someone else had a similar issue and he had a bad plug and there was less than 5000 miles on his. My plugs are about a year and a half old. Maybe I should pull them out in the morning and check them.
FUCK.....MY SPARKPLUGS HAVE OIL ON THEM. I AM NOT A MECHANIC BY FAR AND KNOW THAT IS NOT GOOD. CAN SOMEONE PLEASE TELL ME WHAT GASKET OR WHAT THE HELL WOULD CAUSE THIS....PLEASE
