ok the battery cales on my CB are fried i want to know were should i go to get new ones and how much do they usually run. got some at autozone but they were the wrong one's lmk
I got some autozone ones, they work and the terminals are way more secure.
i know ther secure or w/e but the only have one connection on the stock one i need 2 connections for each terminal Ex: negative cable tranny ground and the one next to the airbox Positive cable one goes to the fuse box the other goes to the starter the autozone one i have has only one connection
They also have little leads on them. Cut the cable that is going to the fusebox and slice it in with that. Then find a 12gauge power wire and put it into one of the little leads on the negative side.
