Well I Tried Tightning it and then loosening but nothing thats with a 200lb of torque gun at 120psi and nothing ima try a breaker bar today i way 300lbs so me and my buddy 150lbs are both gonna stand on it and try it again
Crankshaft Bolt
ok cool.
Dont hurt yourselves now. IT takes a while with the impact gun sometimes though.
heat it with a torch before the breaker bar - it should help.The CB9 has been reborn into a CB3
Members Ride - see my cb3 here - DOHC powah
Check out my JDM F22B swap
Watch my CB7 video
Not unless its acetylene or oxygen. Map, propane, butane won't get it hot enough.Originally posted by cb7wagonPLheat it with a torch before the breaker bar - it should help.
I broke mine loose with a 3/4 inch rachet and a HUGE, thick cheater bar.
Weight is fine and all, but use leverage to your advantage. I'm 178lbs.
I broke 2 1/2 rachets, 1 1/2 breaker bar, and bent 3 cheater bars. This equals a wasted Saturday afternoon.
Also, you may have to wedge the tires to keep them from spinning while you are trying to break the nut loose.Last edited by koffin; 10-25-2006, 03:01 PM.WTB - IACV for H22a4.
FS: 1993 CB9 w/H22a4 and much, much more.
PM or email with inquiries.
Vouch Thread
ive broken more breaker bars than i remember. craftsman 1/2" drive. i usually have 3 during a swap, because one is bound to break.Originally posted by 4CYLPOWER92Were are all these cheap breaker bars comming from? Cause I am always hearing about people breaking them. I got a couple old ones that I swear cannot be broken
I can't afford Snap On, so I "snap" all my Craftsman. I returned 2, 1/2 drives in a matter of 15 minutes a month ago. At that point I proclaimed, "rachets are not breaker bars".WTB - IACV for H22a4.
Vouch Thread
i get it off and im only 130lbs, and i kick it while laying on the ground...
Wtf....Originally posted by cp[mike]i get it off and im only 130lbs, and i kick it while laying on the ground...
lol Better not be 6' tall. Ahahaha!
Ya, breaker bars are better than ratchets though for heavy "breakin." (bb-boyz please do not acknowledge this comment as offensive)
The impact gun works great, just have to use if for 20 minutes to get the bolt loose. It's what I used!
1992 Accord LX - SOLD
Yeah, impact guns are great in that situation. I ended up using a 1k ft lbs of tq rachet gun to get mine off. But whatever rating gun you end up using, you can be sure that there's a lot less of an element of danger involved compared to wielding some 4' long breaker bar.Originally posted by maroonaccord2.2The impact gun works great, just have to use if for 20 minutes to get the bolt loose. It's what I used!
