Hey, I have a couple clutch problems right now. The most obvious one is when I let off of my pedal and sometimes when I press it, it sounds like an old door creaking. The second one is at about 3500 rpm my clutch makes sort of a grinding sound, except almost a buzz. Then it stops instantaneously. I think this is also related to my car making a grinding noise when I shift into 3rd and 5th. I have an Exedy clutch in right now that was installed in February along with a new transmission so I don't think I should be having any of these probelms. Does anyone know what these could be?
clutch problems
clutch problems
My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!Tags: None
bump...come on guysMy Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
dam ur describing the same exact problems i got. The sqeaking I fixed by topping off the clutch fluid. It was a little low the first few days i bought the car & i filled it & it immediately solved the prob. i filled it with dot 3 brake fluid. Check the owners manual before you fill it up though. The grinding, i have no idea, but i need some fkin HELP with it, cuz its getting on my nerves. Hope this helped a little.
But I just put the transmission in there. It had 87000 verified miles on it. Whoever owned that car must have SUCKED at driving if the transmission was a lemon at 87000 miles. I say that sarcastically, I don't think the transmission is the problem.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
i had that problem! i just took some hi-temp grease and put it on the ball of the slave cylinder for the clutch. try that. it might take a lil while for it to work itself in there if you don't remove it completely and apply it that way. but it should work.O'skool fo sho! You might hate, but I been doin' this long before you know.
Bump after 2 years.Originally posted by 93accordEXgrinding when shifting is most likely synchro related... as for the squeaking I agree that it may very well be the actual pedal itself...
I searched and found this thread. I am having this problem to. The clutch pedal makes this weird squeak noise when i press and depress it. I wired up my foglights, and the wires pass around the clutch pedal and at first I thought that was the problem. But it has been doing this before I wired the fogs up. It's a creak sound like the others described. Anyone know how to fix it?
