I Need Help Asap!!
    I Need Help Asap!!
    ok heres the deal...i just installed my delta 272, i cant get the fuckin thing to stay running. I tried everything....adjusting the idle screw, messing with the IACV, FITV, blocking off the boost valve, and still cant get it to idle......im looking at a chipped p06, but right now im in need of some help
    also does anyone have a basemap for an f22a1 with i/h/e/272 cam!!!
    any help would be great!
    TEH SICKNESS IS RISING
    is it starting and stalling or what more info
    did you time it correctly and do you have adjustable cam gears
    the build and demise
    buy stuff i want a new car
      when i start it it runs alittle rough for about 2-5min then it stalls out, i restart the car and it idles for 30sec-1min the stalls and so on and so on....the timing is dead on, and the cam gear is stock
        2 big problems timing dead on with a 272 and a stock gear
        also your map could use a lil tweaking but until then the adjustable woudl help alot
        do you have a manual fpr ?
          i dont have a chipped ecu not do i have afpr....i tried advancing and retarding the timing a couple degrees....from what i read on hondafans setup you dont need an adjustable cam gear....its really hard to do anything when the car wont stay idling
            i was also wondering if completely blocking off the IACV would work as well???
              your gonna need more fuel thats teh thing due to the valve duration its not getting enough fuel and its chokeing out
              hondafan rofl love you cisco lol
