relocating a/c lines
    since A/C is a most this upcoming summer(FL), how would making new lines work....
    say for intense, you could use EARL teflon piping and fittings, would that be do-able?, and would i have to measure the same length as the piping(the low-pressure line that runs in front of the manifold); or could it be any length as long as its pressurized as normal
    what would be the technical aspect of doing this? cause i was thinking that i would run those types of lines along my firewall or ziptie it across my valve cover and/or upper coolant hose
    one more thing, since i cannot use my power-steering hose wont work w/a f22b DOHC, would this method be feasable(sp?) as well?
    "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
    I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
    as long as you use piping that can withstand the pressures that those lines will be seeing, i couldnt imagine custom made ones causing any problems. im sure theres websites out there that talk about things to consider when bending your own A/C lines...
      has anyone tried this yet, i know it would be expensive(i looked it up at about 120 for about 5-10ft), but it would solve all problems w/turbo apps
      yea maybe i should search it but yea just askin....
        ok now basic question: what psi does the components sees?
        a/c
        power-steering
        i want to source lines that will handle what they see normally, or a point in the right direction; searching every tech manual i have but came up w/nothing
          bump, i'm really pondering about this and still getting nothing when it comes to actual pressure ratings(psi) that the lines sees, but i had an idea, i'll try it out 2morow
          would hook up that refill for refrigerant on the low-pressure hose give me a reading?? mine came w/a pressure tester, gotta go did it out
            Someone correct me if I'm wrong, but isnt the high pressure side around 350psi?
            My 5.7 LS1 Holden Ute
              i hope not, or my idea is gone to shit
              but i'm more looking for the low-pressure rating; its the hose that runs right before the headers, running under the upper coolant hose
              but i looked up earl's MAX pressure rating and there a hose thats 350psi MAX, so i hope the lower hose is much less then this
