ok guys, I have a leaky distributor which is the main source of oil leak in my engine. I assume that I need to replace my distributor seal and just want to confirm the procedure in doing this. My thoughts would be to disconnect the negative battery cable, put 2 location markings on distributor ( for reassembly), remove dizzy , replace seal and reinstall while lining up the marks. Is this all which is needed?
Leaky distributor help!
assuming its the o-ring seal, yes thats 95% correct. disconnecting power isnt necessary
then how come it says to do that in the Haynes manual book??? JW...but wierd, didn't know that the distributor could leak oil, or even anything. Guess i'll be on the look out for that in the future.Originally posted by cp[mike]assuming its the o-ring seal, yes thats 95% correct. disconnecting power isnt necessary
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
think about it... the camshaft is inside the head, fully surrounded in oil. the distributor is outside of the head, dry. somewhere between the two there needs to be an oil seal... theres an O-ring around the outside of the tip of the distributor. just about every CB7 ive worked on had a dried out dizzy o-ring, and is the #1 reason for oil being leaked down the side of the head and onto the top of the transmission.Originally posted by Djmouathen how come it says to do that in the Haynes manual book??? JW...but wierd, didn't know that the distributor could leak oil, or even anything. Guess i'll be on the look out for that in the future.
haynes says to disconnect power before doing anything... as long as you dont have the key in and turned to on, doing the dizzy o-ring is so minor, its 3 bolts and its right there... if you electrocute yourself or short something out doing just that, thats pretty sad. lol
Originally posted by cp[mike]if you electrocute yourself or short something out doing just that, thats pretty sad. lol
if that happens...the person shouldn't be working on it in the first place!
MR Thread:
tahaha true, either that or he/she's not car material =POriginally posted by SN2BH22CB7
EDITED: wait...that's what you meant hahha nvm then.
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
thanks Mike, my teacher at school always says to disconnect the damn negative wire so its burnt into my head. I figured my procedure was correct wanted to make sure I was missing something else. And you are so right about it dripping down unto the tranny. My car start right up all the time I doubt I'll need to replace the dizzy. i've been told when too much oil get on/in it I might need to change it.Originally posted by cp[mike]assuming its the o-ring seal, yes thats 95% correct. disconnecting power isnt necessary
1993 Accord LX - Sold
93 BMW 525it - SOLD
92 Accord EX Sedan - SOLD
2000 Accord Coupe - Traded-In
2003 Accord V6 6spd Coupe - Sold
2001 Honda Civic Ex - SOLD
2013 Chevy Traverse LTZ - Kid hauler
2003 Acura Tl 3.2 - Daily Commuter
the main o-ring keeps oil from leaking out between the dizzy and the head. theres also another smaller seal around the main rotating shaft, which allows it to turn but still keeps oil out of the dizzy itself. if this seal goes bad (not as common) youll start getting oil pooling inside of the dizzy housing itself. that can start killing the pickup coils/ignitor. i hear you can buy that seal from the dealer, but from what ive seen, most people just replace the whole dizzy instead of completely pulling it all apart.
[QUOTE='cp[mike]'] theres also another smaller seal around the main rotating shaft, which allows it to turn but still keeps oil out of the dizzy itself. if this seal goes bad (not as common) youll start getting oil pooling inside of the dizzy housing itself. that can start killing the pickup coils/ignitor. QUOTE]
YUMMY..food for thought!
you learn something new EVERYDAY on here!
I been working on Hondas for some years now..and I never knew that!
thanks Mike for the insight!
I thought that O ring NEVER went bad!...never seen that happen before!92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
Ok, cool. I'll just do the O-ring for now. How much would 1 run me at Honda?Originally posted by cp[mike]the main o-ring keeps oil from leaking out between the dizzy and the head. theres also another smaller seal around the main rotating shaft, which allows it to turn but still keeps oil out of the dizzy itself. if this seal goes bad (not as common) youll start getting oil pooling inside of the dizzy housing itself. that can start killing the pickup coils/ignitor. i hear you can buy that seal from the dealer, but from what ive seen, most people just replace the whole dizzy instead of completely pulling it all apart.1993 Accord LX - Sold
93 BMW 525it - SOLD
no more than $20Originally posted by accordtunerZZOk, cool. I'll just do the O-ring for now. How much would 1 run me at Honda?92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
http://www.hondaautomotiveparts.com/...3%29+%28TEC%29Originally posted by accordtunerZZOk, cool. I'll just do the O-ring for now. How much would 1 run me at Honda?
part #6 $1.68
thank you MikeOriginally posted by cp[mike]http://www.hondaautomotiveparts.com/...3%29+%28TEC%29
part #6 $1.68
Thats really cheap!
93 BMW 525it - SOLD
damn thats cheap...why am I being overcharged for them then???? $8.30
for a damn O ring?????
MR Thread:
where did you purchased yours?Originally posted by SN2BH22CB7damn thats cheap...why am I being overcharged for them then???? $8.30
93 BMW 525it - SOLD
