My batter light flickers on and off and stays on sometimes for prolonged periods. This is a completely stock car.
The batter and alternator were replaced last year with all Honda parts.
I checked the battery and it was reading ~12.5 volts with the car off. With the car on and at idle it read ~14.2 volts. With all accesories on (radio, lights, A/C) the meter reads ~13.2 volts. These readings were all taken at idle and the BATTERY light was ON.
These numbers seem reasonable right?
I read how a small chip in the alternator may be sending a bad signal. I'm guessing this chip sends some voltage level or something?
I don't believe tension is a problem either since I get good readings on the volt meter.
I have no clue what it can be : ( Anyone got some suggestions?
Thanks.
Thanks.
