check engine light.
    check engine light.
    my car started throwing the cel. when i drive at a consistant speed the car feels lik its surging. then it will surge one last time and throw the light then it wont surge but when i come to a stop the idle will dive to about 100 and idle rough. when i start to take off the car will bog and then take off. this only happens when im driving. the cel will come off if i turn the car off and back on.
    Cali.Dumps.Harder.
    if its bogging under light acceleration then it could be your EGR valve [i'm having the same issue with the bogging under light accel. cleaned off the EGR valve, trying to do the ports (but they are a bitch)].
    The rough idle could be your IAC
    I could be wrong though
    also, pull the CEL code to verify what it is.
    Member's Page:: Coming Soon
      i tried the iac. where do u pull codes from a 92 lx auto?
      Cali.Dumps.Harder.
        1500 posts...u REALLY should know how to check CEL codes on your CB.
        blue service connetor on the passenger side under the dash, pull it down and jump the two terminals with a paperclip or wire.
        F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
        Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
        Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
          blue service connetor on the passenger side under the dash, pull it down and jump the two terminals with a paperclip or wire. turn ur key to second position and read the blinks of the CEL light on ur cluster.
          1 long= 10
          1 short=1
          example.. 4 long 3 short = code 43
          srry never have a cel.
          Cali.Dumps.Harder.
            count ur blinks over and over again. a pause means that the code is over and it is reciting the next code. so for example 3long blinks + 1short = code 31. 3longblinks+1short+pause + 4long blinks = code 31, and 40. hope that helps
              the codes that FuncOvrForm car is throwin is (12)EGR system Fault, (7)TPS/ Angle Sensor, (8)CKP sensor/ Engine Speed (RPM) sensor, (3) Map sensor circuit.
              the car feels like it wants to shut off, especially coming down his driveway. we reset the ecu and it seems to work for 2 days but today its at it again....
              Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
              -(B-Pillar Bar Originator)-
                good coverage. lol.
                Cali.Dumps.Harder.
                  I would suggest cleaning the EGR before replacing it.
                  1996 Honda Civic LX 2009-2012
                  2012 Kia Optima LX 2012-2013
                    good coverage. lol.
                    fo sho, since its fucking up, i say we do something that'll take us all weekend to do to fix that problem! lol..... ....
                      iight will do it.
                      Cali.Dumps.Harder.
                        EGR stuck open....?
                        Originally posted by kc8enb07
                        does it come w/ jdm trash? they better throw away gold in it
                          mine does the samething when im at highway speed or under hard acceleration it feels like its choking is that what you feel ?
                          UNDERGROUND SOCIETY
                          NEW COUPE MEMBERS RIDE THREAD COMMING SOON
                            at a stop it does. not when driving.
                              yes. then it will choke hard n the light will come on and the idle drops low and strugles to take off.
                              Cali.Dumps.Harder.
