does it backfire
check engine light.
stop wastin ya time and get what ya need to get! u know what im talkin bout!
Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
sic wid it!!!! lol hurry up and do that decal i told ya bout! - "TOUGE" i grip mountains.Originally posted by FuncOvrFormlol see my sig? thats how ima do my lic plate.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
wow, clean egr ports, possible bad egr valve, possible bad dizzy, and tps.Originally posted by cali-racerthe codes that FuncOvrForm car is throwin is (12)EGR system Fault, (7)TPS/ Angle Sensor, (8)CKP sensor/ Engine Speed (RPM) sensor, (3) Map sensor circuit.
the car feels like it wants to shut off, especially coming down his driveway. we reset the ecu and it seems to work for 2 days but today its at it again....
then fix the egr problem first. clean your ports on the intake manifold and I would recommend replacing the egr valve too. then go from there.
