Fixed - High Pitched Squeal
    so which pulley was it exactly?? im gunna do this tomorro
      what kind of snap-on wrenches? I work at tires plus, and we get the snap-on guy, the matco guy, and the mac guy all there..those wrenches are NOT cheap..you are looking at around 300 bux for 8mm-19mm wrenches..jsut plain wrenches!
      -A. Swift
      CB7 member number 137
      Black Doubt Crew member #2
      Ebay Whore Club member #5
      -I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
      AIM: boostinswifty38
      alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
      R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
        a real ghetto solution for ya. take a big candle and hold it to the belts while everything is running. it'll give it a light coat of wax and hopefully get rid of the squealing. if that doesnt fix it... uh... tell us.
        O'skool fo sho! You might hate, but I been doin' this long before you know.
          It wasn't a pulley that made the noise, it was the Alternator Belt. I literally spent 2 hours with a 14mm sprocket wrench tightening it, and it still squealed. The Honda guy gave a few good turns and it has been bliss ever since.
          And the ninjas had sweet victory, and there was much rejoicing.
            -A. Swift
            I think I will probably buy a 14mm and 17mm. The ones I want have swiveling heads. Does $30 each sound right?
              are these the kinda wrenches that are relatively new, wit the closed end, like an open ratchet? I am thinkin for 30 bux, that sounds good, considering I get sumthin like that for around 45..
              -A. Swift
                So what just tighten the shit out of the power steering belt cause I have the same problem everytime I start my car and IV replaced both belts and the power steering pump and nothing
                1990 CB7 *RIP*
                Current-91 EX and 92 EX
                  Replacing the belt doesnt solve the problem. You have to tension it properly
                  FS: BNIB MFactory FD $650, PM me.
                    Do not spray your belts.
                    It is more than likely your alternator belt (if you have A/C, it runs around your compressor as well). Belt squeal on startup tends to be this belt and it should be adjusted for a tight belt tension, otherwise you will get squeal. Also, after a new belt has been on, it may need adjusting in a few days, after that it should run fine.
