Today i drained trans fuild once and then i put in some maxlife atf. But i drove it around for a while and when i was at a light stoped my car started to shake and the rpms droped and the car shook even worse. But then when i put it into N it stoped. It only does it when stoped at a light in drive. What could it be to much oil? not enough. I checked it and it was on the mark. When are u suppose to check it when running or can u check it witht the engine off? And does it have to be on the top mark or can it be a little over? Can any one help.
Car shaking after AFT change???
But my rpms drop and once i put it into N they go back up and shaking stops. And it dosnt do it always only when stoped for a while. And when i put it into N u could hear a grind not good
Thats the same thing i was thinking. Its locking up and making my engine want to stall so the rpms drop. Maybe i will just drop a new trans in there.Originally posted by cmrvi1
That's definately not a good thing..
It sounds as though the torque converter is starting to lock up.
Another possibility is the lockup solenoid is being activated at idle.
Neither problem is a DIY. Have it checked out.
let the car sit on a level surface for an hour
and check the fluid level. i bet its over filled.
if u still dont like it, drain and fill again.
did u use the atf for dextron 3?
i have good experiance with valvaline atf with shudder protection...
do it again or just recheck the fluid level.
smell the fluid too...isit a burnt smell or smells like atf? color..is it red or brown....What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
