I was wondering, if I just get a front polyurethane filled front dogbone mount, will that solve most of the harsh shifting issues? ie: when i shift from park to drive or drive to reverse, i can hear the engine rock and feel it through the car. I know my two side mounts are good, but i know my front is shot and the rear could possibly be bad? i had the rear replaced about 30K ago along with all the others.
Engine mounts, Urethane front mount
97' Honda Odyssey 199k miles...$485 spare van for my parentsTags: None
itll help alot if its really loose, but at the same time the side mounts can sag and still look fine and it will still transmit alot of vibration
it just feels so bad when i shift from D to R and from Park. I feel like i'm beating the shit outta my car everytime i do that.
Bad engine mount
I've got a noob question about engine mounts. I think I may have a bad front mount. I've been hearing an occasional knocking sound coming from my engine, so I investigated it today. I looked at my front engine mount and it looked like rubber stuff or whatever it is in there may be damaged. I'm able to move it side to side with my hand, is that bad?
H22 Fund Cancelled. Flight training underway.
wel what do you think?Originally posted by Scubasteve_danI've got a noob question about engine mounts. I think I may have a bad front mount. I've been hearing an occasional knocking sound coming from my engine, so I investigated it today. I looked at my front engine mount and it looked like rubber stuff or whatever it is in there may be damaged. I'm able to move it side to side with my hand, is that bad?
yes it is not supposed to move...fill the mount, get an insert, replace it entirely or get an insert and fill it.
yeah the mount's supposed to be pretty solid and try looking at it before you take it out to see if any of the rubber is torn, but chances are, if you can move it side to side, its badOriginally posted by starchlandwel what do you think?
I figured it was bad, but I was really hoping it wasn't. I've got a couple other things to fix too. I'm gonna need a new cv joint soon(heard it click a few times today) and I need a new fuel filter and possible a couple other things(mileage is shitty right now). This is gonna get expensive.
the front mount and fuel filter is a cheap fix if your mechanically inclined...dont worry.Last edited by starchland; 12-17-2007, 01:14 AM.
I'm overhauling an airplane engine at school right now, so I do have a decent amount of mechanical skill. I just aint go tmuch experience, especially with cars, the engine bays are way more packed then a cessna is. I'll post up pics and maybe a video of the engine when it's all together and running.
mcmasters 94a i believe is what most people use to fill their mounts.
Me, i got the energy bushing insert but first i filled it with urethane and then put the insert in to make it stiffer, cause otherwise the urethane doesnt have that much to adhere to
cool.Originally posted by starchlandmcmasters 94a i believe is what most people use to fill their mounts.
dan (granitecb7) told to get the prothane insert kit for my car cuz he is getting it and he likes it.
back at it again
Correction, I have Prothane suspension bushings all around but not any inserts. The McMaster's setup is super cheap/effective and lasts for a very long time. So, I suggested McMaster, not Prothane for the mounts!Originally posted by i-07cool.
__
