Screaming for help
    Screaming for help
    last 2 times Ive started my Cb i get this really really loud squeal. it sounds like a dry bearing and once it gets where the temp starts to show on the temp guage. it goes away. i think its the power steering pump bc oil pressure is fine on the engine. but what else could squeal bloodly murder like that? i mean it can be heard 300ft in a brick house... also has only did it when it was 15degree or less
    Sounds like it could also be the aux belts - Alternator, powersteering, or A/c belts, check to see if they are tight or need replacing
    My 5.7 LS1 Holden Ute
      X2 what he said thats what it sounds like.
      Formerly know as accord-racing Jan 06 - Dec 07
      BOUGHT FROM: cb95spd, lildeez07, L3G10N, JARHEAD293, True-BlueCB7, Boost_Lee, djcaz_aom, zmiennik
      SOLD TO: treyd82, Sneakerhead28, BoxMan, civic_90_08, greenmachine9, baracuda, zmiennik
        my 1990 accord did that
        it was the alt. belt!
        too tight or too loose idk but that was it!
        and it smoked! too
        Ride: 2002 Lexus IS300
          haha well belts don't normally smoke like that.. but after checking the belts and they are the right tension.. there is a bearing you can replace inside of the actual alternator that can go bad from belts being too tight. Please don't buy a whole new alternator. If the belts are ok and your narrow it down to the pulley in the alternator.. just buy the bearing for 3 bucks and rebuild it.. it's a fairly easy job.
            hope you dont have bad cylinder heads.. that stuffs costy...
            My Black "H"
            AL Meet!?
            //Secret G2I Lover, Shhhhhhh! //
              i pretty doubt its belts. but the alt could be it. just why rebuild a alt w/ 200k on it?
                damn
                but i bought a whole new alternator a while back!
                but i think actually stopped working or something!
                  Where the hell did that come from?
                  To the OP, sounds like you have a squeaky belt. Rub a little dish soap on the underside (pulley side) of your accessory belts. If the squealing goes away, they need to be replaced.
                  ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                  Project Deerslayer
                  UPDATE: DEER - 2, CB7 - 0
                  '93 EX 5-speed coupe
                  Short ram intake
                  Tenrai Himoto catback
                  Smashed front end
                    why wouldn't you if you know how to do it? You can buy all the internal parts to an alternator and rebuild it for about $150 less than buying a new or refurbished one. If you know how to do it, do it. It just won't be painted like they do when you give them the core back..
