Ok, my mom is having trouble with her car. It's a 1997 Accord SE Auto. Car came with F22B2 Non-VTEC SOHC 2.2L, the engine died last year so we replaced it with an F22B1 VTEC SOHC 2.2L out of a wrecked 1995 Accord EX. I know that the Accord SE is OBDII and that the ECU for the the engine we put in won't plug in so I have to get an OBDII to OBDI conversion harness and wire the car for VTEC function. The car is running on the F22B2 ECU at the moment but it's throwing the CEL. What do you all suggest I do to get the car running properly? Does anyone know the ECU part# for the 1997 Accord EX SOHC YTEC? The only thing I can think of know is to put another F22B2 back into the car and be done with it but, that would be working backwards since the VTEC motor is the same from 1995-1997 and the motor is already in the car. My mom doesn't want to sell the car due to it's condition and cleanliness but, she is starting to get fed up. Can you guy's help me please?
Need Help (Engine Trouble)
I know there is a site that sells OBDII-OBDI conversion harnesses, do a Google on that, I don't see why they would limit it based on 5spd or auto. Contact the people below, speak with them and confirm what part you need.Originally posted by Dionysis24BXTDo they make a OBDII to OBDI conversion harness for an Automatic Tranny car though. By switching from OBDII to OBDI, will the car still be able to pass inspection?
http://www.xenocron.com/catalog/obd-harness-c-29.html
Get the right ECU as well, that should not be hard to find. Look at www.car-part.com and locate it based on a VTEC 94-97 Accord with auto tranny.
You did answer your questions, just pursue it. At this point you already have the motor in the car, it runs, but not well. Just get the missing equipment and you should be fine. You would lose out too much if you did otherwise at this point.
Even better on the conversion harness, I still say you TALK to them on phone to confirm it will work:
http://www.ecutuning.com/product_Ele...arness_62.html
Originally posted by HondaFan81Even better on the conversion harness, I still say you TALK to them on phone to confirm it will work:
http://www.ecutuning.com/product_Ele...arness_62.htmlfrom that linkDescription: OBDII Version 1 to OBDI Conversion harness allow use of OBDI ECU in 96-99 Integra, 96-99 Accord, 96-98 Civic, 96-97 Del Sol, 96-99 Prelude - For 5 Speed Models Only
I say contact these guys and Xenocron regardless for auto versions.Originally posted by HondaFan81Even better on the conversion harness, I still say you TALK to them on phone to confirm it will work:
