I have a H22A4 with a pretty bad problem whenever I get on the gas peddle. it feels like one of the plugs isn't fireing or fireing right before the pistons get to TDC. Everytime it misfires the Check Engine light blinks for a split secound. I took the spark plug wire cover off to find that ALL FOUR spark plug wires were loose
That must have happend when I had the timing belt replaced a few months ago
I took it out for a drive and found it drove fine for about five minutes, ran fine... took it out 15 minutes later to drive home ~20 minutes and it started mising badly again.
Thinking it was a problem with the spark plugs at first I replaced them (old ones were NGK PZFR6F 11) with some NGK Iridium IX plugs. the old plugs were indeed in need of replacement. The plugs came pregaped at ~41. I searched around the net earlier this morning and found the best setting to be .43ish. So I gaped them put them in and took the car out for a test drive. WOW did it feel ALOT better.. at first anyway.
About 30-40minuts of driving the car started to miss again. I brought the car home and looked at the spark plug wires and saw that a couple of them were chared on the metal inside the plug wire (must have been from when they were loose). The plug wires are nology hot wires with only ~15k miles on them. I don't think the wires are bad. however the plugs inside the wires look like they've seen better days
So with that, what do you guys think the problem(s) could be??
I'm thinking spark plug wires are something I should think about getting. But I'm unsure about the other ignition components.
I took it out for a drive and found it drove fine for about five minutes, ran fine... took it out 15 minutes later to drive home ~20 minutes and it started mising badly again.Thinking it was a problem with the spark plugs at first I replaced them (old ones were NGK PZFR6F 11) with some NGK Iridium IX plugs. the old plugs were indeed in need of replacement. The plugs came pregaped at ~41. I searched around the net earlier this morning and found the best setting to be .43ish. So I gaped them put them in and took the car out for a test drive. WOW did it feel ALOT better.. at first anyway.
