radiator. . .
    radiator. . .
    can I fill it with just water or do I need to add coolent. Because mine leaks and im sick of buying coolent and dont want to fix it yet.
    U MUST fill it wit coolant! If u fill it wit just water, the motor will not be cooled sufficiently. Coolent raises the boiling point of the water, and witout it, the water in the radiator and system will just boil, and cause you many, many problems..
    -A. Swift
    CB7 member number 137
    Black Doubt Crew member #2
    Ebay Whore Club member #5
    -I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
    AIM: boostinswifty38
    alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
    R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
      just make sure u displace the same amt...
      mines had a crack and it kept smoking.. and it got irritating haha..
      but ya.. i think you should go fix it.
      hahahahah
        Well a good trick that some professionals tell me is that if you add aunt jemimas syrup then it wont leak as much, WORKS GREAT, you should try it!
        Just playin bro yeah definatly upkeep on teh coolant and go to autozone and buy a replacement radiator when you can Good luck
        To have loved and lost is better than to have never loved at all #CB7Life
          if it's a lil leak in the rad, try this "bars mixture" stuff you can buy in stores, in a grey bottle i used some in the DEAD of winter last year and it actually worked pretty good, cept it'll leave alot of brown shit in yer rad if you use to much.
          ~~~~~~~~~~1991 ExR alb F22a6~~~~~~~~~~
            Dood... don't you guys watch Mythbusters?
            crack a raw egg in a hot radiator and it'll seal that leak...
            RIP Lifsatrip7
              Well, you dont have to add coolant.. but itd be a good idea if you wanted your engine to run properly.
              To-Do List for Today
              Be Awesome
                pepper my friend......not the fine kind the course ground black pepper.....99 cent section of ur local super market....i garuntee it will work.
                Finally Up and Running. Numbers to Follow. Check my MR
                  my friend used this on his radiator a few days ago he said it was the best 4 bucks he ever spent. he was filling like 3/4ths of a bottle of coolant a day before.
                    I'd be hesitant about using any 'stop leak' kinda stuff, as who knows what it'll adhere to and gum up inside the coolant passages in the engine. I would not use it and simply replace the radiator or whatever's leaking.
                    Get it done and over with; you'll end up spending as much money over time with 'snake oil' as you would just buying a new one.
                      You beat me to it. I was going to say the same thing. Funny how it actually worked though.
                      -'93 Accord EX 5-speed F22A6
                      -DIY mesh grill, DIY stealth intake
                        Re: radiator. . .
                        Tap water is bad for your cooling system. Also, if you have an O.E. water pump, I would use the ready mix from the Honda dealer ($10). I have been getting all my radiators from radiator.com. In my accords I have the 19VI (visteon) for $80 delivered. It is plastic tanks/aluminum core. I am putting one in this weekend. too easy. When I do this on older vehicles I replace the upper/lower hoses and thermostat. Get-er-done. Saves messin' with it latter. Unless yer gettin' rid of the car.
                        TBILL
                        92 Accord EX Coupe
                        CB7, 5 spd, Seattle Silver
                        91 Accord LX - no mods
                        CB9, Auto, Cobolt Blue Cooking with Clinton
