20v 5 inline
    20v 5 inline
    is there somebody that tunes those motors
    because those motors have caught my attention 4 a while now
    and just saw it like a f22 with more power and dispaclement
    also the sound must be sickkkkkkkkkk
    Just do what PR CB7 said.
    That would be the engine out of the Acura Vigor. I'm sure there is a forum around someplace that is dedicated to them. As far as swapping one in, it would be extremely difficult and would require quite a bit of fabrication because it is a N/S mounted engine instead of transverse, like the Accords. I don't think I've ever seen any of the common mods (I/H/E) made for them, so it might require some custom work just to get simple bolt ons.
    As far as power goes, I think they fall in between the H23 and H22. The Wiki Article on the G engine (which is that engine) says 176 HP and 170 torque. I'd imagine that you could pick up a lot of torque doing some mods, because it is an inline.
    So, as far as swapping, I think the H22A would still be a better swap, just for strict ease of doing it. Although, it would be interesting to see what could be done with that engine. I think that you would be going into largely uncharted territory, though. I'm sure there is a forum dedicated to them someplace, though. Try Google.
    1992 Prelude S w/swapped H22A
      Not only just fabricating how the engine site you have to mod it to wher eti will line up with the trans since it is a unit with the motor itself.
        Doesnt the axle go through the oil pan or some insanity like that?
        To-Do List for Today
        Be Awesome
          damn..i was thinking of a volvo motor at first...nevermind.. good luck trying to figure that one out
          Current Stable:
          1992 Accord EX
          1999 Civic SI
          2005 TSX
          2006 S2000
          2002 NSX-T
            volvo motor 5 cylinders are rwd. You would have to figure a way to convert.
              I swore I saw an old video that said in Europe the cb had an option for a 5cyl
              wat?
                It was the engine in the 1993-97 Ascot/Rafaga. It was longitudinally mounted, and wafflefries is correct, the driveshaft came back through the oil sump to the differential at the front.
                http://www.geocities.com/honda5c/intro.htm
                ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                Project Deerslayer
                UPDATE: DEER - 2, CB7 - 0
                '93 EX 5-speed coupe
                Short ram intake
                Tenrai Himoto catback
                Smashed front end
                  The 850 on was FWD or AWD depending on model.
                    Ya I was thinkin bout the older 740s.
                      The G20\G25 was longitudinally mounted as in the pic.
                      and yes, the shaft goes thru the oilsump. Doing any gearbox maintenence on the Inspire\Vigor was a pain.
                      BIG PAIN.
                      Click sig to view MR thread
                      Links to other rides:
                      Honda Accord Euro-R
                      Honda Odyssey Absolute
                      Honda City I-DSi
                      Honda Stream
                        The Acura 2.5TL also had the 5 cylinder engine with the "normal" engine&tranny mounting geometry except that the differential is incorporated into the engine oil pan.
                        You'd think they would suck to remove but really aren't that bad. Disconnect the tranny from the engine, remove radiator and the engine lifts right up with no clearance issues. I swapped a blown one out and it took my working by myself no more than 5 hours to remove. Very smooth running engine, sounded a little strange but not bad. The biggest advantage to this type of engine/tranny FWD setup is that the front/rear weight distribution is much better giving the car a more neutral feel naturally.
                        Oh yeah....these engines also have IAB's in the intake!
                        My Member's Ride Thread
                          Same here.
                          Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
                            Originally posted by Otto
                            Same here.
                            The Ascot and Rafaga were based on the CB7 chassis.
                            Project Deerslayer
                            Short ram intake
                            Smashed front end
                              Not that gen Ascot.
                              The SM3 Ascot and SN7 Ascot Innova were CB based.
                              The Rafaga had a bespoke chassis, quite similar with the Inspire/Vigor
                              Honda Accord Euro-R
                              Honda City I-DSi
                              Honda Stream
