ENG: Battery Servicing
    Battery Servicing
    *******THIS DIY IS FOR NOOBS AND GIRLS THAT DONT KNOW HOW TO DO THIS**********
    Have you ever gone to start your car and it wont cut on the lughts wont llight up and it wont do a thing
    well there could be a few things wrong
    im going to talk about the most common
    Battery Corrosion
    battery corrosion is that crap you get usually on your + terminal its green blue and looks weird
    well that can prevent your car from starting turninging over or in this case even lighting up the dash board
    here is how to fix it
    first open your door and pop your hood
    now open your hood
    and take a look at your battery
    now you are going to want to take off the battery hook ups (you might need some tools, basic pliers and adjustable wrench will do)
    now you are going to want to take a wire brush and brush off the corrosion on both battery terminals even if there is none
    and the wires for the car brush them down too, inside and out
    now replace the car wires and tighten them down and replace the red positive cover if you have it
    close the hood
    and get in the car
    and try to start or turn the car on
    ''It is what it is, Do what you want''
    http://www.cb7tuner.com/vbb/showthread.php?t=167905
    Just to add to this - If you have a battery where the inspection holes can be removed - Like the OP's second pic.
    Check the electrolyte levels.
    If they are low top them up with distilled water.
    My 5.7 LS1 Holden Ute
      modern batteries are maintenance free adding distilled water could do more harm then good and you're opening yourself up to get injured.
        Opening a sealed battery (maintenance free) would be stupid.
        Refilling an open top battery (as per the OP's picture) is perfectly fine.
          you know i was thinking of adding that to the post but
          i guess i forgot
            i guess i forgot
            it also helps to add a conductive / non corrosive lubricant example, anti seize or Vaseline.
            ( the anti corrosion sprays/gels get messy and believe it or not have either promoted corrosion or non conductivity more so than w.o such products. so i stay away from those anti corrosion sprays/gels personally )
            frostwhite225@gmail.com =VENMO
            http://www.youtube.com/watch?v=NOB38zJu66o
            [COLOR="Magenta"]
