In my case I went a little above and beyond with the hidden location. I want to keep every thing clean and stock looking. Most installs will be similar if you have an after market radio
I went with a XM Direct Tuner with Nav Traffic
1: Find a suitable location for the receiver. You need to pick a place away from heat and moving objects and with decent ventilation
2: The satellite radio antenna is magnetic and is best installed on the outside
of the car. You can install it inside on the dash but your reception may suffer. The most common locations would be on the trunk lid, and above the front or rear windshield. You will need to run the cable to the satellite radio interface. careful it is relatively fragile
basic diagram from Sirius same applys to XM
3: Next you need to get signal to the source
In the case of Pioneer you will have an ip bus cable (in my case also a data cable) to the head unit and you will need to hook up ground and constant power. (standard yellow)
Sony uses there proprietary din cable and RCAs to "bus audio in"
JVC uses there proprietary din cable
For my install I took out the rear side panel in my coupe.
I built a mount out of MDF. And secured it to the brace.
Ran the ip bus, data cable, and power with ground to the screen/ head unit (pulled sill plate and ran with factory wiring).
I then place the satellite radio antenna on the top the the rear windshield and tucked it in the weather seal. Carefully running it through the trunk to the location of the module
