1. If your check engine light is on, start by going to your passenger side kickpanel.
There should be a blue connector w/2 wires to it like the one pictured below.
Put a paper clip, wire, connector in it to connect the two prongs.
2. Put the key in the ignition, and turn the key 2 clicks to the acc on, where all the lights light up on the dash.
3. You will now watch how many times the ABS light blinks.
4. Compare to this list to see what the problem is:
Long blink = 10 short blink = 1
Code 1 - Problematic componet; Other Componet
Code 10 - Pump motor Over-Run; Pressure switch
Code 12 - Pump motor circuit problem; Motor relay unit fuse Motor fuse
Code 13 - High pressure leakage; Solenoid
Code 14 - Pressure switch
Code 18 - Accumulator gas leakage
Code 21 - Parking brake switch-related problem; Brake fluid level switch, BRAKE light
Code 31 - Front right Pulser
Code 32 - Front left Pulser
Code 34 - Rear right and left Pulser
Code 41 - Front right speed sensor
Code 42 - Front left speed sensor
Code 44 - Rear right speed sensor
Code 48 - Rear left speed sensor
Code 50 - Rear left and right speed sensors; Modulator
Code 54 - Rear right speed sensor; Modulator
Code 58 - Rear left speed sensor; Modulator
Code 60 - Fail safe relay ( short ) Front or rear fail-safe relay
Code 61 - Fail safe relay ( short ) Front fail-safe relay
Code 64 - Fail safe relay ( short ) Rear fail-safe relay
Code 71 - Solenoid related problem ( open ) Front right; ABS B3 fuse
Code 72 - Solenoid related problem ( open ) Front left; ABS B1 fuse, Front fail-safe relay
Code 74 - Solenoid related problem ( open ) Rear left and right right; Rear fail-safe relay
Thank you aero for the layout and the CEL plug picture.
Hope this helps everone
