Originally posted by F22HB
View Post
SUSP: Replacing Rear Rotors w/ Pads
Originally posted by The G-Man View PostScrews, not hard at all.
Turning the piston on the other hand is a bitch. You have to take a needle nose pliers and hold them open around the piston and push while turning.Originally posted by bakedaccord_90 View Postthe tool we used to loosen those screws was an impact screwdriver. It works really nicely if the rotor
lock screw is stuck. Striking the rear of the driver simultaneously seats the bit into the screw
and rotates it counterclockwise to loosen the screw and turn it clockwise to tighten.
we bought the tool at autozone for around 10 bucks
hopes this helps out makes the job real easyBut I'm about to try the needle nose method, I was just turning it with vice grips, no pressure applied.
Leave a comment:
good write up just what i needed. and ima look for those brembo blanks.
Leave a comment:
This suck... my driver side didn't have screw on... and it was super easy to replace. Then come passenger side ...... Got that damn screw on it. I couldn't take it off ><!! I heat it up with heat gun and try to use the drill to screw it off and It strip the head a little...... I was like F this shit...that shit not warp and still new (4 months old) soooo now i got new Brembo Blank on my Driver side and Some No name Brand on Passenger Side
any suggestion on that little screw?
Leave a comment:
Originally posted by 91-accordyeah, it's super siezed and somewhat rusted!!! damn it! Any suggestions???
Leave a comment:
Leave a comment:
how about replacing the rear caliper??
That one little bolt/pin that is pined onto the caliper bracket. what's the best way to take that off.
Leave a comment:
This thread is just a further reminder that I need to swap out the *** ass rear drum brakes on my LX.
I HATE DRUM BRAKES!!!!!!!
Leave a comment:
/\ good info there. i used a impact drill. I tried everything i could and then my neighbor let me borrow his work drill and it did the job
Leave a comment:
Leave a comment:
