made out of aluminum, took 30 minutes.
NOTE: Installing an EGR block-off plate with a stock PT3 or PT6 ECU requires the EGR valve to be electronically & vacuum connected, as well as the EGR control solenoid in the emissions control box. If you have chipped ECU that does not recognize and EGR system, you are all set (ie. P06, etc).
