ENG: Wire tuck
    Since I'm deleting my AC can I move my blower motor the the AC condensers location
    New heart and soul H22A4
    Bought from: King James,kouzie,xkjnboix,tommi
    Sold too: P5ylance,GearBangnAccord
    Traded with: crazymikey,nine_deuce
      Are you keeping heat. If so remove the condensor but not blower
      NEW CB
      new
      DARKCLOUD : 90 ACCORD EX MRT
        Ya I'm keeping my heat, so since the condenser is out ill have to do is place the blower in the condensers spot
          No remove the condensor out the black casing and reinstall it empty or buy the condensorless duct from honda
          NEW CB
          new
            okay i started on this last night. and its going smoothly just about done but can i delete the black container on the inside of the driver side fender? it has a vacuum line going to it and i dont want to delete it if i need it for smog. here in cali smogs a bitC* so i dont know if i can take it out. i mean its in the fender so how could they see it? let me know guys. thanks!
            this is what im talkin about.
            http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
            http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
              I think that's for the cc. I deleted it from my car with no problems.
              Click picture for MRT
              Sparkin CB7
                What about the section of the harness with the orange/yellow/black wires that has two female ends? Just a section that has same plug onboth ends..
                -Tyler
                  Vss I believe. its its own 3 wire harness.
                  NEW CB
                  new
                    i just finished up my drivers side last night! this is a great DIY!
                    heres mine.
                      Ok, I'm having a problem with running the headlight harness on the driver's side. I have the harness deloomed all the way up to the engine harness plugs and I ran it through the wiper motor grommet, now I need to run it through the oval hole but then it seems like the harness isn't going to be long enough to reach the lights. So do I need to deloom it more or do I need to route it some other way?
                      Help please.
                      Edit: here are some pics for reference.
                      Sparkin CB7
                        Tun it under the fender
                        NEW CB
                        new
                          I just had it laying over the fender while I was delooming it. It is ran under the wiper motor and through the oval hole behind the fender already.
                          I'll get some more pics after a bit.
                          Edit: from those pics it looks very misleading and makes it look like I'm a dumbass and trying to run it over the fender
                          Sparkin CB7
                            I know you were doing it right. but did you used a rubber line to keep the frame from cutting
                            NEW CB
                            new
                              Like a grommet? Yup, I'll be putting a couple on.
                              There is some vacuum line on the metal under the wiper motor that the wire goes under. I'm also going to use some vac line or a grommet for the hole behind the fender. :tu
                              Sparkin CB7
                                I would actually like 2 start a small tuck. I have abs so that's more stuff to look at. All I did was take out the cc and ac. Whippy do da. I want to keep my fuse box abs box, and fuel injector box/wires.
                                Idk maybe I'm thinkin of it in a wrong way.
