Well....... picked up the ECU.
.... and started looking at it. This poor ECU, I'll never buy a ECU from the company that sold it to me again. (*cough* HAMoto.....*).
Let's look closer
....hmm crusty pins? and ..... slagż?..
Using too much heat when soldering (too big of a tip)
hmmm.... this is how a water damaged PCB usually looks. But why mine?
This ECU I never opened as it would have voided the warranty. The first one we had to send back as it wouldn't connect to SManager. There were always issues with dealing with the company I bought this from. And now that I've finally opened it, wow! This board has 'too much heat', not enough solder, "slag" on the tracers, appearance of water damage.... .. just wow. Yet the car ran fine for two years.
So... I cleaned up the board. And now the part you'll like....
The ECU works now. (not a good sign, but.... let's see what happens here)
Took the phone along for the first start...
So we went from this......... cowboy, circus show, wtf battery, who the what
To this. Graph is stretched out a bit but ... more stable. Everything is more stable. The initial lean condition when returning to idle is normal. The .25 mark is what we are focused on. I'm ok with this, although the car shutters like it's sick at this moment.
But......... there is bad news. The ... issue ... is ... still ... present. UG.
As the car sat at operating temps and things started to heat up and the "recovery" at idle suffered worse and worse....
So over the course of 30min or so...
1.
2.
3.
Cell phone vid - It still like to dip into lean a few seconds after returning to idle for no reason. Sometimes it lingers there too long and the car shakes.
And all of this changed because I scrubbed the board with alcohol and a toothbrush and did the capacitor kit on it.
So........ ya. Still need another ECU to test. Doh. I'm almost starting to think about the main relay now too...
Let's look closer
1.
2.
3.
