I got a 92 accord ex coupe and i want to look into my egr passages. Anyone ever use one of those newer 5.5 mm cams. Here is a link to a ranking of a few
https://wiki.ezvid.com/best-usb-bore...ditors_choices or you can see a list at amazon . I need to be able to see in there to find one of those brass plugs that fell in and got hidden(in the very corner on drivers side i believe) whiled tapping my egr ports with threaded ones. I think with it taped to a coat hangar(due to cable softness) it will fit in there but not sure. Those 5.5 mini cams have side cam attachments to look sideways also, so i think that will be able to easily see the corner if it wont snake thru. Wanted to ask if anyone ever used one.
