I ordered an oem front right axle and i got what it seems is the shaft and outboard joint. No inboard joint. WTF. IS this normal. Part number is 44010-SM4-A11 . That shows a complete axle. I don't even see a part number just for outboard joint, boot, and shaft. I do see where it shows a separate part for inboard joint but not outboard. Can i just replace the outboard. That is the part that is leaking. That seems like a pain having to join the one that is on car now with this new one. WTF is that store thinking(amazon seller). I don't want to call them and cuss them until i am sure i am right. What yall think.
Not a complete axle. Just outboard sent. WTF.
I agree, from what I can find, 44010-SM4-A11 should be the complete drive shaft assembly. The outboard joint (without the boot) is 44014-SV4-950 or 44014-SM4-020.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostI agree, from what I can find, 44010-SM4-A11 should be the complete drive shaft assembly. The outboard joint (without the boot) is 44014-SV4-950 or 44014-SM4-020.
I've learned to rebuild various things on my car (steering rack, power antenna, fan motors, etc), but I've never bothered to mess with axles - just replaced the whole assembly. I figure if one end is bad, the other may not be too far behind.
On my car many years ago (before I started doing most of my own work), I had Tire Discounters install axles with a lifetime warranty. Just got my 3rd replacement on the right side (about 90,000 miles each).90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
